i did not read every post here but can you post the part number for the low mount a/c bracket or where might it be posted on hear . thanks.
Hi,
Sorry for the slow reply - I was traveling in Europe for work and just got back last yesterday...
Here is the link for the brackets. They are, as CoronetDarter stated, from Bouchillon.
https://www.forbbodiesonly.com/moparforum/threads/hawk-rod-the-restoration.65096/#post-910005909
The system woks, but like anything in life, there are trade-offs. Good is it hides your A/C. Bad is (a) you must ditch your mechanical fuel pump (b) the system really strains the belts to run the A/C, so I need to re-set the belts every year. You will also need to replace belts more frequently.
Hope this helps,
Hawk
