Propwash
- 2:36 PM
- Oct 29, 2009
- Island of Misfit Toys
Hey Gent's......Gotta Electrical Question
I'm currently in the process of converting my headlights system on my bird to not only a relay driven system but also HID with the H4 and H1 headlamps. I'm trying to set up the system to run quad lighting (highs and lows) when the highbeams are engaged. Main reason being is the short delay with the ballasts when engaging the circuit.
The set up is quite a bit different than stock, so typical wiring is out the window. The HID bulbs have a single + and a single -, with no jumping to each. Anyways, I'm running a relay for the lows and one for the highs. The stock signal wires from the headlight switch for the high or the low beams go to each applicable relay.
My thought was to splice the high beam trigger wire (before the high beam relay), and jump that to the low beam trigger wire and splice into one to meet the terminal on the low beam relay. I also thought of installing a diode in that jumper wire from the high to low so when I just had the lows engaged, current wouldn't flow in the opposite direction across the jumper and activate the high beam relay, thus all 4 lights on no matter what. On top of that I figured to put another diode on the low side before the splice so not to worry about current flowing back up towards the headlight switch. I'm no electrical wizard, but can handle my own....In this case though I feel i'm digging a bit too deep or going further than I really need to with the diodes being it's DC...
Any thoughts would be appreciated..Pic below
