67 GTX
Voltage at my headlights (could only check high beams) are only at 7 volts, causing them to be very dim.
I have begun troubleshooting. The headlight switch is removed, so that is removed from the equation.
I found the two power terminals in the headlight switch plug, and jumped them till the headlights came on, trying both power terminals (not to each other). Voltage was 7 at the lights, which was the same as when the entire system was assembled.
Possible issues:
Corrosion in foot high/low beams switch. Switch works, but perhaps corrosion built up causing a lot of resistance?
Issue in firewall plug. I think this is unlikely, since i had that plug off last year and cleaned all the contacts.
Issue in the fuse box. Could be at the fuse itself, with the contacts corroded, or at the contact going to the box itself.
Corrosion on the lights themselves, although I find this unlikely since both lights had the same voltage going to them.
Has anyone else experienced this issue and/or can suggest something that I missed or haven't mentioned?
Possible issues:
