First, I apologize for the disagree. My phone took a tumble on the concrete and has a oh so slight hairline crack across the display glass. It distorts the rating icons. I will not rate any posts until I get a new screen, or phone (or rate on the PC).
Second, I want to comment that everyone is not thinking about this properly. As an engineer who has worked in the electronics industry almost 38 years, I am always amazed that people often ignore the elephant in the room when discussing voltages across a harness, circuit, etc etc. That elephant is the VOLTAGE DROP. Don't think that a 1V drop still produces good headlight illumination, but think about that 1V drop as creating HEAT. A voltage drop is the equivalent to wear and tear of your circuit. In this particular subject, the wear and tear is the bulkhead connections, and the headlamp switch itself. As corrosion, dirt, grease, etc build across these voltage drops over the years the HEAT increases. As the heat increases the wear increases, and yes, the voltage drop increases.
Nothing wrong with cleaning all of the contacts and connections to reduce the voltage drop. This is the right thing to do and corrects the problem, but the relay addition basically reduces the current load, which reduces, or virtually eliminates the voltage drop from the circuit.
I will be ordering the crackedback kit soon myself. I added the 'police harness' to my Grand Marquis years ago not because I wanted brighter headlights, but that change protects my GEM module from ever burning out. The relay will protect your bulkhead and headlight switch from ever burning as the same sort of fix.
