Hello FBBO and friends. info on these wheels
74moparguy
5:02 AM
Tulare, Ca.
just wondering if anyone would know anything about these wheels, name, year, value, etc. thanks for the help
Looks like centerlines for 73 Datsun 210 or 310. Or 74 something Toyota Celica. I had a older cousin who I think had similar with green center like that on his Celica back in 78 or 79. Haven't seen anything like that since then. Very long time ago.
I thought most of those old Japanese cars had 4 bolt wheels.
Got any measurements for the bolt patterns...4.5 or 4.75 bolt circle?
those are champ 500 centerlines from the 90's.or most likely copies.is there a bead of silicone around the center of the wheel.(would be covered by the tire if it had one mounted up)if it has silicone bead then real centerlines.if solid(one piece cast wheel)then it is a knock off.
A.R.E made those also called them Champ 500. Look on the back it will have there name in it (casted)
Also I think Owtlaw 1 ?
I agree but I think my cousin narrowed a pick-up's rear and modified the engine to run 4 Webber side draft carbs on the engine with modified cams and was crazy fast for that small Celica.
