lucien440
New Member
I have a 383 with big cam all kinds of upgrades.i did not build the engine.the valve train makes noise.stock rocker shafts.pops through carb.sounds like bad lobe.did some research.if you use stock valve train.you must use different length pushrods.i dont want to go to roller rockers,etc.what duration and lift and centerline,can i use to just use stock components,with no modifications.i can not find specs for original camshafts.now i know why they call it mopar madness.would appreciate any suggestions
