help identifying wire near wiper switch
Interesting. Althought I can’t see a reason for that since motors are the same and switches are virtually also the same as far I recall. And wiring to bulkhead is also the same, running into the same 4 ways plug. Engine bay harness side is also the same.
A bodies are also the same. In fact talking on A bodies the only difference is between foot pump washers or electric washers. This are the only physical difference on switches where electric washers wiper switch are press in shaft and foot pump are fixed shaft. Sooooo if you install a electric washer system on a foot pump car, you need to add the wire running between switch and bulkhead (and of course on engine bay side aside the change the reservoir)… on A bodies at least. Even this, plug to switch remains the same, just one cavity left empty on foot pump cars.
Also up to 74 on A bodies, two speeds wipers are foot pump, while 3 speeds are electric pump washer. Then from 75 all are electric. Maybe similar to E bodies hence why the wire difference you found? Was that extra wire for 3 speeds a brown one?
You can even install a B body switch onto a A Body or backwards and wiring and plugs (if same year) will be the same. But the physical size/lenght of the switch will allow or not this posibility. Thinking the same about the E bodies.
I have never owned an A body but I know on a B and E body, the two speed switch has 6 terminals and the three speed switch has 7 terminals. They have different part numbers as well. I only know this from doing swaps from 2 speed wipers to 3 speed wipers. I remember the 7th wire being present in the harness but not used on the 2 speed. I agree the harness is the same but the switches are different.
The extra prong is ground, not used, since switch gets ground throught the chassis. As I told, on my 74 originally 2 speeds Charger I did fit a 71 variable switch setup which I got included with the 71 Rallye cluster I got and didn’t change or added anything more than the plugs change since 71 uses diff prongs disposition (also two separated plugs instead the one piece plug of the 72/74s ). But wiring did remain the same.
As I said before. I agree the wiring harness is the same. Try using a 2 speed wiper switch with a 3 speed motor. There is a reason they have different part numbers.
Sure… diff functions too LOL. Contacts are working diff inside between both switches.
