daniel_depetro
- 2:16 AM
- Jul 22, 2008
- Sterling Heights, MI 48310
I will definitely re-weigh the car again, as I get free weighs on a local certified scale.
It was a super lightweight (if there is such a thing..hahahaha) base model Coronet.
Do I mean base model.
The only thing it originally came with were Am radio & the chrome mouldings (drip rails, belt line, B-pillar, and rocker panel).
I mean the dash is all steel with no plastic trim panels covering it even. I didn't even think they made them like that in the 1968-70 B-bodies.
Of course everything is manual and being a coupe I don't have any window winding mechanisms in the rear either.
I do not carry the jack & spare tire around in the car either.
Granted neither is serious weight, but just helping show why this one maybe lighter then most fully dressed B-bodies.
There is definitely more weight to be lost though as the body is 100% steel and I have not cut anything up, though I doubt I ever will on this car.
However I would like to get a new set of headers so I can get a mini-starter to fit, as well as upgrade to the 10.5" clutch & flywheel set-up with a blowproof belhousing (right now I am using a stock 11" flywheel, cast iron 11" belhousing, and 11" 23-spline perfection clutch).
The transmission is a 1970 all cast iron 4-speed unit and the driveshaft is a factory 1968/69 Road Runner piece.
