Help please not sure on flex plate
Jbland
2:50 PM
Texas
I bought a 360 5.9 casting(53020006-360) for my 68 charger. I'm using an a904 trans and need to know which flex plate is correct? Will the one from my 318 or 440 work? Thank you.
I think you just need a small block flex plate. I may have one if you need. I'm not 100% sure on this one, but I think you need a torque converter from a 360. I believe a 360 is balanced via the torque converter. Can someone else confirm this???
