Help starting my engine(hopefully)
Bens69PlymouthSatellite
5:49 AM
IN.
Im going to be starting my 440 here in a couple of weeks on an engine cradle and I could use a little walk through on how to do it any detailed info would help I have a pretty good idea but just wanna be sure thanks!
The basics:
Go over everything and make sure things are tight and holes are plugged. Put in oil and coolant. You can run the oil pump with a 1/2" drill (in the same rotation direction as the distributor) to prime it or leave the plugs out and crank it over for a bit. Will need manual trans flywheel (with proper balance) and bellhousing so you can hook up starter.
Pre start:
May want to leave the rad cap off so you can see water circulating as it warms up. I always boil my T stat before use! Do not get the engine too hot. Firing order check (1-8-4-3-6-5-7-2).
Static timing check. Set engine to 10 deg BTC with #1 cyl on compression and rotor pointing to #1 plug wire. Turn dist until the points just open, or the reluctor is just off the mag pickup. The coil fires when the primary connection is broken.
Gas in carb and initial carb settings done. Idle speed screw about 1 - 1.5 turns from throttle blades lightly seated in bore. Idle mixture about 2 turns out from lightly seated. Float level set. Holley will have the gas at the bottom of the sight hole. AFB about 7/16" top of float to gasket.
Just remember that the 440 distributor rotates counter clockwise, where the small block is clockwise.
Assuming this post rebuild or post reassembly...
Safety first.
Safety glasses. Everyone should own these, no one wants to be blind.
Wear earplugs, its going to be loud. Don't put the last one in until she is started. listen close during cranking.
Fire extinguisher - I don't have to tell you why. Yes experience is golden.
Kill switch. Make sure you can shut it down fast if something sounds wrong.
Personally, I always install a basic set of gauges. oil pressure, temp etc. You can get basic cheapys almost anywhere. Yes I have a set of sunpros, they work for bench testing for "yes/no visual indicators". Get mechanical so its easy to "wire them". Trust me it sucks if the oil pump isn't working and you don't know it.
Prime oil pump - yep this is critical. Verify oil pressure gauges registers your prime.
Fan on radiator if you have it on for some time.
No alt? Have that battery fully charged. With alt, keep clear of those moving belts!
Chock your stand wheels. She will "walk away" when she hits high idle or a lumpy cam.
Resist the urge to rev. Yeah, I see them do it on TV too, resist. Let it follow a normal warm cycle etc. so you can see what it does. Manual choke, you are on your own. That is what you are doing it for, right?
Don't sweat smoke, But pay attention. There is normal smoke and abnormal smoke. Learn to identify which is which.
Ventilate: it may be cold outside where you are, but don't kill yourself with carbon monoxide.
Buddy system: Don't do it alone. Have someone (anyone) nearby in case you need "help".
Randy
Side note: I had a friend who did a rebuild and rebuilt the carb and made some mistakes along the way. She started right up and ran badly, he went to rev it (getting close to the carb), I guess he misinstalled the secondary jets and the timing was off, it backfired into the carb when he revved it and the flame nailed him. He was alone and no fire extinguisher in his garage. I'll just say he needed a trip to the hospital.
Let's be safe guys.
