gottagettamopar
Hi all
I just tried to fire up my Coronet after a couple of months doing various jobs.
I've rewired the engine bay, moved the battery to the trunk, added a relay for the starter and another for the GM HEI ignition module, put new plug leads on, replaced the steering box, rebuilt the heater box.....you get the idea.
After three hours of dead car yesterday I found the ignition wire had pushed out of the bulkhead connector.
Thing is, it's now coughing, burping and farting but it won't run. I think it's taken on too many of my characteristics!
I've checked TDC and the zero degree timing mark to ensure the rotor is pointing at #1.
I've checked fuel and spark and both are present and correct.
Engine is a 383 Magnum, carb is Holley 750 Vac sec, not sure about the dizzy but it's billet with no vacuum advance. I've set the reluctor gap at 0.008".
Any suggestions gratefully received.
