HEMI RR
I was mocking up the federal power steering pump on the 70 Road Runner to check belt alignment. I have the HEMI only power steering pulley on the pump and before I return the install tool I wanted to make sure the pulley is not on to far. After mounting it on the engine, it looks like It would line up to a third pulley. I have a 2 groove crank pulley and both pulleys are the same diameter. The alt. and water pump are using the inner pulley. Some pictures I have seen show a 2 groove crank pulley with a smaller outer pulley offset unknown. I have the thicker HEMI Damper. What pulley do I need to correct this?
