Hemi Oil Restrictors
Bob maio
5:56 AM
Hebron, CT
First, I need to mention that I am posting this question for a friend that is computer illiterate. And I am hemi illiterate so its not a good combination. Rich has an aluminum 426 hemi block (part #426-B4-MWB) with Indy cylinder heads. The heads were built back in 2012 and he is just now getting things together. The engine is partially assembled. Between the two heads is a braided oil feed line. When he purchased the heads, he also purchased head oil restrictors (part # 426-R4-27R). He is not sure where these restrictors are installed, if they should be installed, and which of the assortment that he received are to be used. I know this is vague, but I am trying to help him out as best I can. Any help from you guys would be gratefully appreciated.
Bob
I'd call the place he bought the stuff from.
Indy Cylinder head first call.
Maybe they have a better or different system for this 12 years later.
Take a look on the head for the oil feed hole. Might not be there, hence the lines that go to the back of the block
