OldRunner
Hello
I am setting up a 528 Hemi, I am running Dual E Carbs on an original manifold. Manual Brake car.
Should I use a PCV valve on one side and a Breather on the other ? Should I run the PCV to Vacume on the rear carb ?
When I bought this car, they have a breather on both valve covers with hoses attached, hoses just hang down past the valve covers, not sure if this is the way it should be ? Can it get vented properly this way ?
