FOR SALE HI PERFORMANCE 273CI COMMANDO ENGINE
Slickfish66
10:36 PM
Canada BC
1966 273ci Commando Complete Rebuilt bored 30 over new Dome Pistons 10:1 compression Falcon Ultimate Cam Shaft Kit Cam Street & Strip 287 dur 480 lift , Double Roller Timing Chain, Hi Volume Oil Pump, Steel Crank , Heads Port Matched to Edelbrock LD4B intake manifold, Engine block and Crank Shot Peened, block and heads deflashed and deburred Original dual points distributor, Original exhaust manifolds, 625 CFM Competition Series Carter carburetor, have original 273ci Commando Intake manifold, Machining and short block assembly by Pression Performance Machine Shop in Penticton BC
6,500 CND
Less than 3,000 miles on it !
Serious Inquiries Only!
