high beams issue
Damien B.
6:16 PM
France
Hello again second thread of the day for me after a long time being iddle
I m changing the headlights from my 71 satellite, the previous owner had install (and made a total mess with the wiring) some xenon headlight that needed a bunch of relay, resistor or ballast and didnt even light the road properly i m getting ride of this and decided to get some LED 5.75 headlights with H4 connexions. I m trying to figure out how to connect the headlights properly because when i press on the foot switch for the high beam the headlight turn off on my instrument cluster i see the red diode telling me the highbeams are turned on.
The previous xenon headlight were switching from low to high beam properly even thou you couldnt see anything at night
If anyone did the same conversion can you offer any suggestions ? Wrong resistor ? wrong wiring ?
found out what the issue was, the switch on the relay wasnt activating.
