Superbee069
New Member
Been working on a 69 charger... low beams work but when you flip on high beams all the lights go out.... I tried a working dimmer switch and that did nothing... I checked two grounds to the left and right of the radiator if that's makes sense... also when when the turn signal is on it seems to be robbing power from the headlight as in it flickers very very slightly.... what else should I check? Any help is appreciated very new to this kinda stuff
