'72 Charger
So I'm about to put my stroked 360 back together and I need to iron out this little detail.
I'm installing a MSD HEI distributor, 10.5 mm wires, iridium plugs, 6AL Ignition w/limiter, high output coil and 100 amp alternator.
Here's my conundrum, do I need to install a voltage regulator with this setup? I understand that merely upgrading the old 78 amp alternator to this new 100 amp I would need a regulator.
I haven't found any specifics about whether I need to install on with this setup.
