FOR SALE holley 1050 XP dominator and indy intake
stage3
1:06 AM
california
Feedback: 5 / 0 / 0
barely used holley XP series 1050 dominator, the latest version thats infinitely adjustable. if its been ran its only once i cannot smell any gas from it. i bought this and the intake thinking that i will 1 day put them on but im staying with the theme of my car, max wedge crossram which i have a modified unit i will be running so someone mite as well get to use these ..
over 1500.00 with tax from summit,,,,,,1050.00 Shipped to the lower 48 ONLY....
Paypal okay as long as its FRienda s and Family ONLY, No goods and services.
indy dominator flange intake with max ports, Also used maybe once, has had some port cleanup as shown, doesnt appear to have been cutters just flapper wheels.
990.00 with tax , 640.00 shipped to the lower 48 ONLY.
Again,,,Paypal okay as long as its FRienda s and Family ONLY, No goods and services.
save alot of $$$ right here,,offers
I would be interested with Paypal goods and services, im happy to pay fees
950.00. carb.
475.00 intake.
carb spec's.
Features:​
  • All aluminum construction saves 3.8lbs. over original models (28% weight savings)
  • Shiny with red anodized billet aluminum metering block and booster inserts
  • Designed for use on Drag race, Pro Street, or any high horsepower engines
  • Calibrations optimized for today's larger race engines and new fuels
  • Fully machined from venturii throat to throttle bore for predictable & repeatable performance
  • Integrated idle bypass valve allows for adjustment of idle while maintaining correct throttle plate to transfer slot relationship
  • 12 hole billet booster inserts for superior atomization and crisp throttle response
  • Metering blocks feature improved durability, true gasket sealing and fully adjustable (emulsion bleeds, power valve channel restrictors & idle feed restrictors)
  • Dual 50cc accelerator pumps provide the perfect amount of fuel from idle to full throttle
  • Fuel bowls provide 20% more fuel capacity while controlling slosh with internal baffling
  • Clear sight windows on both sides of bowls for easy and safe fuel level adjustments
  • Built in drain plug in front center of bowl provides easy access to empty contents of bowl
  • -8 (o-ringed) inlet threads offer a large variety of plumbing options and can be plumbed from either side
  • Factory ready TPS mounting points for use with data acquisition systems (Holley TPS P/N 534-214 available)
  • Knurled (hand adjustable) primary and secondary curb idle screws allow for easy idle adjustment without the use of tools
  • Contoured hex head squirter screws for streamlined airflow
  • 100% wet-flow tested by Holley technicians to assure it arrives ready to run!
  • Fully adjustable stainless steel external linkage can be adjusted for 1:1 progressive, or soft progressive throttle activation. No linkage parts under the carburetor
intake SOLD !
carburetor still available...
easter sale, 850.00 on the carb. Free shipping to the lower 48 ONLY.
