Holley 6105 Metering Block
Daves69
1:10 PM
ChiWest
Evidently it's for a Holley 2300C.
Anyone happen to know the carb list / application for it?
Also, if ya' know, what's the difference between the 6020 and 6105 metering blocks?
TIA
Dave
I've got a technical list of every (it seems) Holley ever made. The typical part# for a primary metering block is ***-***, so I can't help with your numbers. See if you can find a different number.
Typical number I found for a 2300 iprimary block is 134-137.
....See if you can find a different number....
It took a while but I finally found some pictures of the 6020 when the set (six pack) was apart last year. Not seeing the engineering number that you're asking for and I have only these three views of it without taking it apart again. Possibly a Chrysler proprietary item?
I don't have a 6105 but I'm considering one for another six pack set.
The 6105 is listed for a 71 440 center carb. I got this info from Bill Overcash and /or my stash of carbs. He’s a six pack guru. They should be close enough. They made subtle changes in carbs. The later model replacements were different still. Front and rears were both the same. No so on assembly line cars.
