Did you get your kit from Holley? Real live Holley brand not a generic kit from a parts store? One sign of a generic kit being used is that your bowl was stripped. Generic kits, especially the ones that use a big brass jam nut to tighten the unit, are off by one thread on the thread pitch leading to stripped out bowls. The gaskets that are supplied may be cork based, which shrink, or incorrect paper type, both of which can have the holes off leading to poor running. Another thing to check is lay a straight edge across the main body where the metering block and throttle plate attach to the base[ minus the parts and gaskets]. See if its warped. If so, here is another problem area causing poor running. File or machine the three surfaces flat if needed. For awhile Holley was getting cheap on the amount of screws that attach the throttle plate to the main body. Its set up for 8, but they only put in 6. If yours is like this, add in the other 2. Also, any cough back can pop or screw up a power valve. The valve may hold vacume but will still not operate properly. You can add a check valve to it to prevent this. Holley and some others offer this or you can do your own for free. This is something I learned about long ago so its an easy deal to do. If you floats are toast, get the brass ones. The nitrophyl units don't get along with ANY alcohol which is in our gas even when your are not aware of it. Another thing may be that your metering block has junk in it that cannot be removed by anything. I dealt with this for a couple of years on my sixpack. Cleaned it, run fine for 10 minutes, then crappy again. Put the unit in an ultrasonic cleaner and OMG, LOOK AT ALL THE FECES COMING OUT! That made it last for 30 minutes. Finally replaced the block, end of discussion. Another thing on filters. No filter made will stop rust from getting in and plugging things up. The only thing that will stop the rust, which is in your tank or the one at the station, is to put a magnet on the filter. If you are running a metal inline unit, find a FWD Mopar trans pan magnet. Very strong and has a hole in the center which will fit over the filter outlet.
