Wietse
Hey all,
I am thinking to take the swap to EFI, i got most of it sorted out how i want to set it up, apart from my doubt in choosing between the Sniper and Stealth Sniper.
Apart from the difference in appearance, which is not my real concern i did read that the Sniper Stealth is easier to hook up the throttle and kick down linkage as it remains in a near same position compared with a normal carb.
Apparently the normal sniper unit is a fair bit wider and therefore require some modding on the throttle cable and linkage.
Down side of the Stealth Sniper (to me) is the duel fuel feed which requires another $60-120 assembly compared to a directly hooked up single fuel feed on the normal Sniper.
The Stealth comes around $100 more expensive, including this with the needed dual feed line it does turn out higher but i am not sure if it is worth the extra $$?
Both are good for 650 HP which is sufficient for my engine, but since the standard Sniper is a 800CFM and the Stealth flows at 870CFM.
Would there be any reasons to pick either one for a 440 engine?
My engine has a Hughes Engines HE3844BL cam which only gives about 7" vacuum at idle.
Currently using a Edelbrock Performer RPM manifold, which should work....although I've read different opinions about the Single plane/Dual plane story.
Anyone some good advice?
Thx for reading!
Thx for reading!
