Wietse
Thx threewood
I've seen your thread about your installation.
I went with a OEM style pick-up with in-tank pump.
This kit has a build in regulator so i only needed to run a single 3/8" fuel line with filter assembly to the engine bay which was very easy compared to any external regulator or return line.
Starting i guess will be something i will need to spend quite some time on to get it right, my engine only produces around 7-8" hg vacuum so even for the EFI it is not easy to keep that going when cold.
When the engine is at normal operating temperature it runs fine, but that was the same with the carb.
