Sweet5ltr
Yeah I've run into timing lights that wouldn't work with EFI before. Not sure what the deal is with that but I've seen it. I have an old Craftsman timing light and it works just fine with the Hyperspark so I guess I got lucky there.
Sounds like you're having some sort of issue but I don't know what it is. You do need to be super careful keeping all of the ignition wires away from the Sniper wires. The Sniper is sensitive to RF noise so everything needs to be separated. You also need resistance plugs and resistance wires or else it won't work.
Thanks Andy,
Timing light works fine once the engine is running, won't operate spinning the engine over like the manual states is required to verify timing.
Currently has Accel 416S plugs and MSD 8.5mm wires, less than a few hundred miles on them, plugs are new, they worked fine with the Sniper prior to the Hyperspark install. I'm going to rewire it today (or tomorrow) after work and keep all the new wires separated with braided loom. Ordered another timing light that will arrive today, we'll see if this one works. It has to be something simple I would assume.
