Holley in-tank fuel pump module
El.Padrino
5:03 AM
Austria
Hey,
any experience if the Holley in-tank fuel pump modules such as part 12-314 (255 LPH) or 12-384 (350 LPH) read the fuel level correct at the gauge?
Or are they the same as the standard chinese fuel sending units that will only read about half full with a filled up tank?!
I installed one of these in tank pumps but it had an aftermarket sender installed on the other side of the tank hooked up to some aftermarket gauge. The pump works great but as far as the sender side of it I cant tell you if they are accurate. Read the ohms when the arm is up and down and see what they say. But according to the specs they should be correct. Here are the specs as follows. Note the red lettering.
Specs
Application1968-70 Dodge Charger, 1968-70 Dodge Coronet, 1968-70 Plymouth Belvedere, 1968-70 Plymouth GTX, 1968-70 Plymouth RoadRunner, 1968-70 Plymouth Satellite
Average Flow Rating255 LPH
BrandHolley Sniper EFI
Connector GenderMale
Emission Code5
Free Flow LPH255
Fuel Filter IncludedYes
Fuel Sending Unit IncludedYes
Fuel Sending Unit Ohms73-10 Ohms
Fuel Tank Pressure Sensor IncludedNo
Fuel TypeGasoline
Gasket Or Seal IncludedYes
Grade TypePerformance
In Tank or ExternalIn Tank
Inlet Diameter (in)5/16 IN
5/16"
Inlet QuantityOne
Lock Ring IncludedYes
MakeDodge/Plymouth
MaterialSteel and Plastic
Maximum Pressure58 PS
ModelB Body
Negative GroundYes
Outlet Outside Diameter3/8 IN
Outlet QuantityOne
Product TypeFuel Pump Module
Pump TypeElectric
Regulator IncludedYes
Resistance Ohms Empty73 82
Resistance Ohms Full10 82
Sale CategoryAir and Fuel Delivery
Universal Or Specific FitSpecific
Vent SizeN/A
WarrantyLimited 90 Day
Wire Harness IncludedYes
UPC090127062586
Part Number12-314
