1969 beep beep
Hi,
Just wondering if anyone has run into this problem before. I installed a Holley Sniper on my B engine on a 69 Roadrunner manual transmission. I am having an issue with the sniper throttle. It is kind of difficult to drive this thing from a dead stop. It feels like the pedal is kind of firm then it’s very aggressive to the point where it chirps the tires. Driving it makes me feel like the first day I drove a manual trans. Lol I have read up on this issue with the sniper.
I purchased the Holley throttle lever extension. I am running an aftermarket Holley street dominator with Ar engineering tall throttle bracket. I know adding the extension will make it easier to open the throttle blades because of more leverage by changing the geometry, but I can’t get the stock throttle cable to work. Without the Holley extension the stock throttle cable works perfectly on the Sniper with the AR throttle bracket. With the extension the cable is to short and pressing the pedal won’t open the throttle blades to 100%. Cable setup worked perfectly on my Holley Carb.
Not sure if I need a Lokar throttle cable or a different throttle cable mount.
It’s like the cable needs to be extended but doesn’t have the travel to open the blades to 100%
Any help would be great.
