alpentolic
When I bought this '74 Box Van I was handed an Edelbrock Performer and an old Mopar-Specific Holley 4160 carb (List 6495). The PO had split the exhaust into duals and said there was a mild summit cam in it, but the old 2bbl is super worn out so i am putting this setup on.
It has a couple fittings I don't recognize from other 4bbls. The elbow coming out of the float bowl I'm guessing is an overflow? But the other side doesn't have one. It pulls right out.
The tube coming out over the top of the choke there is pressed in and goes straight through to the top of the intake. A vent tube I don't recognize I guess.
While I'm at it, I'm trying to find a good place to connect my pcv hose. I couldn't find much on what openings in the Performer intake are vacuum. I was told it was the rear 2. One I have hooked up to Power Brake hose (seems weird to run it all the way to the back of the intake but that's how the stock one was set up). The other I put a 3/8 fitting on, but not hooking up until I know.
I'm sure I'm leaving things out so thanks for helping and let me know. Much appreciated!
