Hood Safety Latch
RR Fan Dan
If it ain’t broke, fix it till it is.
8:05 PM
Virginia Chesapeake Bay
Does anybody make a billet hood safety latch? Getting tired of touching mine up when it gets scraped up.
Is this a half-million dollar, numbers matching, one-of-few, concours restoration, trailer queen? If not, stop worrying about it. If someone ever says "that's beautiful but you have a paint chip there", hoof 'em in the nuts !!!
I believe the release lever was originally in black phosphate, but I recall seeing originals that look zinc galvanized, too. Not sure if that was B or E body, though. Even so, I learned many years ago detailing B & E bodies for shows, to hold the safety catch partially open when closing the hood, to ease the hook past the hole in the latch plate, lest it scratch the paint on the lip of the latch plate hole.
Contact cement a piece of edging rubber on the rear edge of the latch tray hole.
I like this idea, but it's not for everyone, as the black rubber piece may be just as unsightly (to some) as scratches on the plate.
Thats a good idea, but Rish may be right about it showing. I will have to check it out and see if there’s a way to do this.
No, but it’s very nice. Obviously you don’t have OCD like me. I definitely agree with kicking em in the nuts but if there is a solution i obviously want to hear about it. i know I’m not the only one with this problem that’s been bugging me.
Well a 2" black piece of rubber on a Dark Green car, or chips... take your pick.
I have a strip on the Bee and the Wife's '67 Formula S as they both require the "Jay Leno" hood drop to close the hood. Doing otherwise you'd be denting the hood trying to close them.
Have you considered a plastic block inside the 2 hooks that protrudes enough to eliminate the metal to metal contact? Say I think I will do that on mine!
Mike
Do you have a picture of how you did this.
Now thats a thought, but it would show more than the rubber suggestion.
OK. I made a UHMW filler piece to fit inside the hooks. It stands proud of the steel so only UHMW touches the top grill header. It feels smoother and is quieter to boot.
Mike
That is pretty ingenious. What is UHMW? Did you drill holes and screw it in? I was thinking epoxy would work to fasten it too.
Calling @dadsbee do you have pictures of what you did?
Ultra High Molecular Weight Polypropylene plastic. It is common in many products. I used some leftover snowmobile slides (dealers seem to only stock slides for long track sleds and I used waste). It is available from Mcmaster Carr.
The last photo shows the screw heads.
Mike
