- 9:00 AM
- Aug 18, 2024
- Virginia Chesapeake Bay
Does anybody make a billet hood safety latch? Getting tired of touching mine up when it gets scraped up.
Which part is at issue? Pictures help.Does anybody make a billet hood safety latch? Getting tired of touching mine up when it gets scraped up.
Why is it painted?Does anybody make a billet hood safety latch? Getting tired of touching mine up when it gets scraped up.
Because the previous owner painted it with the restoration. Would a stock latch not scrape up? I have been looking at this one.Why is it painted
You could just hold it open when closing the hood.Does anybody make a billet hood safety latch? Getting tired of touching mine up when it gets scraped up.
Not sure how that would work. gotta drop it so as not to push on hood and opening would still scrape.You could just hold it open when closing the hood
Contact cement a piece of edging rubber on the rear edge of the latch tray hole.
If you read the ad its also painted.
Thats a good idea, but Rish may be right about it showing. I will have to check it out and see if there’s a way to do this.I like this idea, but it's not for everyone, as the black rubber piece may be just as unsightly (to some) as scratches on the plate.
No, but it’s very nice. Obviously you don’t have OCD like me. I definitely agree with kicking em in the nuts but if there is a solution i obviously want to hear about it. i know I’m not the only one with this problem that’s been bugging me.Is this a half-million dollar, numbers matching, one-of-few, concours restoration, trailer queen? If not, stop worrying about it
Well a 2" black piece of rubber on a Dark Green car, or chips... take your pick.Thats a good idea, but Rish may be right about it showing. I will have to check it out and see if there’s a way to do this.
Do you have a picture of how you did this.I have a strip on the Bee and the Wife's '67 Formula S as they both require the "Jay Leno" hood drop
Now thats a thought, but it would show more than the rubber suggestion.Have you considered a plastic block inside the 2 hooks that protrudes enough to eliminate the metal to metal contact?
I'll make one tomorrow and post it.Do you have a picture of how you did this.
ThanksI'll make one tomorrow and post it.
That is pretty ingenious. What is UHMW? Did you drill holes and screw it in? I was thinking epoxy would work to fasten it too.OK. I made a UHMW filler piece to fit inside the hooks
Ultra High Molecular Weight Polypropylene plastic. It is common in many products. I used some leftover snowmobile slides (dealers seem to only stock slides for long track sleds and I used waste). It is available from Mcmaster Carr.That is pretty ingenious. What is UHMW? Did you drill holes and screw it in? I was thinking epoxy would work to fasten it too.
Calling @dadsbee do you have pictures of what you did?
