ToddMcF2002
I'm assuming the metal stub is for turn signal cancel? Is the assembly pressed in or glued in you think?
Yes! So why didn’t the test light work? So I guess this contact ring is my problem after all. It might not be touching?
Yes, primary function is the turn signal cancel. Also holds the slip ring in place, spring tension around wheel hub. Can be carefully pried off. Insulating washer and compound separates the ring from the cancel spring and hub. I would find out why the contact is not contacting the slip before removing the slip ring. If you take it apart, be sure the cancel spring/peg is clocked correctly going back together.
Test lights? gave those up years ago.
I have a multimeter but test lights are still useful for quick triage. But I won't forget this one since it left me completely confuzzledyup after spending too much time in a flat rate shop chasing a problem with the test light like this I bought a DVM
