SOLD Hotchkis rear sway bar 2255R
timsatellite
12:38 AM
webster ny
I have a brand new Hotchkis rear sway bar for a 1966-1970 B-Body for $250. This is the 1"hollow bar with the 'dog bone' type links, It is model 2255R, it is brand new , I mocked it up on my 67 Satellite and realized it interfered with the tailpipes, so it was never used. I have all the hardware, brackets instructions etc. This will fit a 66 or 67 car but not if you have a stock tailpipe setup, 68-70 should be no problem. This unit sells at Summit for $366.
Could you measure how wide it is? Looking for one for my project. Thanks!
Just an FYI. I have one on my 67 belvedere. No exhaust yet but the sway bar fit perfect.
yes it fit perfect, but the tailpipes on the 66-67 run right under the rear frame rail along the edge of the gas tank and that is where the dog bone links/mounts are installed. i had it on the car and then started to install the exhaust and realized it was no good, really disappointing, so it has been hanging on the wall for a couple of years. time to find someone who can use it
I’ll measure and see if it’ll fit. Thanks!!!
I finally got a moment to measure and it’s to wide for my set up. Thanks for providing the measurement.
