How do you remove moldings / trim?
67possible
10:00 AM
Hillsboro, MO
I have a 67 Coronet and I want to remove the side moldings, window trim, drip rail trim, and that stuff. I am going to wrap it with matte black vinyl and then put most of the shiny stuff back on. I have never done any kind of body work before and don't want to damage any trim pieces. Do I need special tools to remove/install? Any help at all would be appreciated.
Wow, thanks rsd859, that helped a lot! I am ordering one of those hooks now. Still open to any more information I can get on removing molding. I saw someone removing drip edge molding with an old bottle opener. That made me a little nervous, but I will try to be careful. Thanks again for your help.
I just tried the bottle opener on the drip edge molding and it worked like a charm! The window trim though, that's a whole different story...:black_eye:
On window trim get the tool and move it along under trim. When you feel the clip push it in and lift up trim carefully I also used a 2 inch puddy knife to lift trim a bit to see where clip's were . Once you get doing it it's pretty easy. Do not force anything or bend it. Side trim is pretty hard to get off without breaking the plastic clips I got all my trim off perfectly but broke about 1/2 of the clips
Rick E just did a how-to article with good photos in Mopar Action (last issue, not current issue). His removal tool looks similar except it has a left and right hook like a U-shape. Slow and steady...I like the putty knife idea
