madelectrical states a falste statement... they saye are moving the main splice outof the cab with their mod, which is not truth... the main splice is still inside the cab and thre is no way to move that making what they did. The main splice Is the one which feeds the fuse box, ign key and lights too.
I'm not saying the ammeter couldn't melt the cluster, loose it own studs from the internal gauge plate, crack the isolators etc... I'm not saying the bulkhead 56 packard terminals are the propper one. Everything on stock form BEING THE POOR ALT OUTPUT ALT the first fail on this design, then the weak terminals at bulkhead are the main problems on the stock design. What I'm saying is whit an alt able to feed all the car demands at iddle ( no matter if 100 amps o 1000 amps ) will save you the back and forth ammeter bounce, and the bulkhead bypass, no matter if running a parallel ( keeping the stok ones if still in good conditions ) or removing stock ones and just using ones at a side of the bulkhead, is SIMPLY ENOUGH to keep safe your car. No need for more mods or magic tricks. Not even needed a shunted system, stock system with the propper upgrades is simply enough and I have prooved that. Several guys more have tried the same with same sucess.
If you get a good alt the battery won't ever feed the lack of load the alt is not able to give iddling at the OTHER side of the ammeter, When this happens, giving gas to the engine alt will recharge what the battery lost on te previous stance once again croosing through the ammeter. This is what the back and forth needle movement tells you. Saving the load going through the ammeter will save you from heat there, so no more problems there. With this, the only next problem to deal are the bulhead terminals which ACTUALLy making just the alternator side should be enough, but, better make it on both sides ( batt and alt ) in case of an alt failure. Done.
Why this is so hard to understand and accept ? and once again why you despite my own experience on my own car with this mod made maybe 8 or 9 years ago? and my car IS ( actually is at body job, but was ) my DRIVER car, using AC every season of the year ( I live in tropic ), being the AC blower the most load sucker device in all the car ?
I'm not despiting what you say, just exposing what is not necesary to make if you want to kep your car working like factory did, keeping your ammeter working as ammeter and not converted to voltimeter.
then if ppl preffers make those ( unnecesary ) modifications, go ahead... but let him know there is an easier and trustable way to do it keeping everything like factory did makes no hurt.
If ppl want more, here is a GRAPHIC way I posted all the load runs through the charging system and how it works. If you made to understand this, you can't say I'm wrong. And my car with stock 40 amps ammeter and actual 100 amps alternator ( although it seems to be more like 80 amps ) have prooved what I exposed on graphics on my STOCK FULL LOAD ammeter system. I even recorded a video showing what aammeter shows on my system just that can't find where is to post it. Shows EXACTLY what I did on diagrams
http://www.dodgecharger.com/forum/index.php/topic,33574.0/all.html
and, once again, there is a failure added by car owners on their ignorance about how the charging system works on ammeter equipped cars which is feed any extra added accesory from BATTERY side... totally wrong what adds stress on a system prone to failure from factory underloaded designed system.
ANY ACCESORY MUST BE SOURCED FROM ALT SIDE OF THE CHARGING SYSTEM, fuse box is like that, factory accesory sources are also on that way ( from ign switch ). If you need more BATT sources than factory gave you on stock harness, just need to add a junction point OR use the ammeter stud, buth any of both on ALTERNATOR side of the game.
wondering how many cars got a premature failure on their cars because of this ? I bet the battery positive lead must be getting LOTS of wires there added on these cars... and still on stock poor alt.
Now everything of this is exposed, it at each own to choose what they want to make.
