19Charger74
I'm having problems figuring out a short in my ignition system.
Wondering if someone could help me out or get me going in the right direction.
How can I check to see if the Distributer pick-up coil is good? I know when cranking it should send a signal, but how much? Will a ohm test show its fine?
Also I have a 4 pin ECU. The wires going to the dist don't show any voltage even when cranking. Can i just do a resistance ohm test to make sure its good?
My issue is that i get no spark from coil in start, even through the coil has power. I've also swapped out ECU, Voltage reg, Ballast, Coil, Dist pick-up cleaned all connections, checked all grounds, Checked fuses.
