RustyRatRod
Great right up and.... Nice crocks.
Them things are the most comfortable shoes I own. lol
May I just ask where you bought this tool for $115 shipped.
Sven
till you drop something on them
Great "how to" post. I think I might attempt cam bearing install on an old chev 350 engine I'm going to build.
I've been doing this for a few years myself, and just like Rusty said, it's not rocket science. But you do have to pay attention! I can also say that listening to some Allman Bros or good blues music helps the installation process :sideways tongue:
Damn good write up, and I like your avatar...alot!!
Yup, that's exactly what he does when he gets a tight cam.I did machine work for about 5 years. Yes, we used the same tool way back then and did on occasion have a cam that was a little tight. We always kept old cam cores to use as tools to cut some cam bearing material. We took a wix wheel and cut a diagonal notch in each cam journal and lubed up the old cam and installed it while turning it. The notches act like cutters and clearance the cam bearings just right. I had an old school machinist teach me that when I was a kid. It works well. As I said in the write up though, if you're careful and keep that cone tight against the block, your bearings will be straight and you'll not likely run into that problem.
