How to store and engine
1969 beep beep
11:05 AM
Fl
I am pulling the motor out of my car. There is nothing wrong with the motor but I am replacing it. The engine is still in the car and runs. I have drained the oil, added a new oil filter and fresh oil with lucas oil stabilizer. I plan on fogging the engine while running. Do I have to drain the oil from the motor when leaving on the engine stand? What about the coolant, should it be drained from the block? i plan on spraying some fogging oil in the cylinders and turning it every couple months. It probably will be on the stand for more than 5 years.
wen I store one for long period of times fog it back off rocker arms tape over all holes and build a cradle for it to set on out off 2x6s I don't let them hang on a estand for long.............Artie
