Stucat
I have a 2010 6.1 manual transmission set. When I did the install in 2011 I used the Mopar performance plug and play setup. the charging system was fine. So 6 months ago I decided to get a better system that could be tune and make the engine run better with todays technology. Purchased a Holley Terminator X 3550-1225. Having a few electrical issues. One is the setup has no setup to use an alternator. Called Holley Tech line , not to much help. I am sure I am not the first or last person to have this issues. Any help or info would be great. I also found out that the terminator won't work with a push button starter, they say because when you push the button flow is cutoff for a fraction of a second. this is the alternator I have now. powermaster model #11392 D/C 11702.
