lewtot184
last time i checked those crane springs i got [email protected]", [email protected]". springs do vary some.Yes, I would estimate the open/closed pressures to be 314/141 lb, respectively - using 1.85" installed height. Looking at the Crane 99839 spring, I compute open/closed pressures to be 307/103 lb. I called Crane to chat with them, and they also recommended this spring. They indicated it would work with stock retainers and no head machining required.
If I use the Crane springs, do I need to shim them to bring up the closed pressure at all? Is 103 lb high enough?
Thanks.
