You will get it. Simple system so should not be too hard to find the problem. Good luck.
If he has a full high petal after bleeding the rear brakes, I would think they are adjusted right. If he doesn't have a full petal right off the free play, then you have it.I'm still going with rear shoes not set out close enough to the drums Jerry, but I hope he's rolling and stopping!
otherwise it will go to a repair shop
I wish all I needed to do is bleed brakes.. I’m rebuilding/replacing the entire hydraulic brake system. Couldn’t do anything on the car other than cleanup the inner fender this weekend. My Sacrum has been badly out of alignment the past 4 days.. Have had chiro adjustments and massages for it. Has hurt like a bitch and making me walk with a limp. Can barely roll over in bed, and get in and out of a car, let alone crawl underneath one.. So the Super Bee continues to sit in the garage waiting to be worked on.Cant drive the car much but did go far enough to use the brakes many times.. they work as they should, its just been decades since i used non-power brakes.. i cant explain why i had all that trouble but i am good with the results. and moparguy68, bleeding brakes it easy if thats all you need to do.. what i did was a bit more complicated !! Let us know how that goes !!
You will be doing what i just did.. complete overhaul, thankfully my lower back cooperated.. now i have to wait 2 months to have the steering and front suspension replaced.. i am too old to that work myself.. hope you feel better soon.I wish all I needed to do is bleed brakes.. I’m rebuilding/replacing the entire hydraulic brake system. Couldn’t do anything on the car other than cleanup the inner fender this weekend. My Sacrum has been badly out of alignment the past 4 days.. Have had chiro adjustments and massages for it. Has hurt like a bitch and making me walk with a limp. Can barely roll over in bed, and get in and out of a car, let alone crawl underneath one.. So the Super Bee continues to sit in the garage waiting to be worked on.
I think crawling under the car and fighting with that damn rear brake hose C-Wedge, on the previous weekend, contributed to or caused my current condition.
This is the last project car I’m working on without a four point lift.. Not going to do another with jack stands. I’ve had it.. Two years of this is enough.
