- 5:22 AM
- Sep 15, 2009
- State of insanity
Which Chrysler vehicle was the first to use Corinthian leather?
1974 Chrysler Imperial Lebaron
Darryl and DarrylName the two original Dodge brothers - first names.
Bert and Ernie.Darryl and Darryl
What is the maximum flow rate achievable on a set of stock 318 cast iron heads?What's the firing order for v8's.
What gap do you set v8 points to.
Where is the vacuum modulator located on a 727/904.
What is the yoke span difference between 7260 and 7290 series u-joints.
Where are the glow plugs located on a Cummins.
Clearly, spellcheck is your worst enema.Damn you, SpellCheck! Corrected. Thanks
What year’s was the Daytona pick up produced and what colors were available.
2005 only one year
Go Mango and gray, were the only two colors offered.
This is mine and it does have a lot of metallic.To be more accurate....
Classic Go ManGo was more orange with less metallic. The Daytona trucks were darker and had more glitter than our classics did.
If you refer to the hood from a 1969 Barracuda, they fit the 1973-76 models.What 1969 hood was also used on a different 1974 car?
Makes it too easy??If you refer to the hood from a 1969 Barracuda, they fit the 1973-76 models.
