I have always tried to keep names out of it but he said it first, ABS is the one I'm usually referring to when I speak of disappointed. Before buying AMD I purchased the Dutchmen panel, rear valence, trunk floors and right inner fender from ABS for my charger with a lot of disappointment. The trunk floor wasn't to bad but didn't have the lip that spot welds to the taillight panel, if your trunk is gone why doesn't a new panel come complete? The Dutchmen panel, like the trunk wasn't complete and required being welded to the old one all the way across the trunk opening just under the bend "talk about a nightmare to fight warpage" not to mention I still had the rust in the trunk opening to deal with that would have been taken care of by a complete Dutchmen panel. The inner fender required a big hammer to make fit around the shock tower, then a lot of body work to make look good and on top of that it doesn't even look correct compared to the original. The rear valence wasn't bad, I suspect with all of the points that have to be matched up most would require some work to make fit perfect. AMD on the other hand fit great and came as a COMPLETE panel, I even chopped the other Dutchmen panel back off used it for clean donor metal and replaced it with a COMPLETE AMD panel that fixed all of the rust issues and was way easier to install. Tailight panel no issues, full quarters no issues other than getting them tucked under the roof which the tech guy at AMD was more than willing to help me with. I don't understand why people make incomplete panels, if my trunk is so bad that I need a new one why would they think that the oh so important part of the trunk that fastens it to the taillight panel would be any good "that's what PATCH PANELS are for". Anyways, ABS will get the job done but with a lot of extra work, I had to make the missing lip for the trunk and weld it onto it and if I didn't have a break I would have had to pay someone to do it. I'm not lying when I say the AMD full quarters only required hammering down two little high spots right behind the doors on the top side "that's it". I also should mention that I purchased my ABS metal probably 4-5 years ago so maybe they have gotten better "hopefully" because I always try to buy American. P.S I board sanded the coating that came on the AMD sheatmetal just for the heck of it and they blocked out almost all the way without any filler "that's quality".
