SOLD Icon Piston set with total seal Rings
JohnEngland
12:21 PM
Northern Illinois
I ordered the pistons and rings and decided to go another direction with engine build. I paid $730 will sell for $550. These pistons can be used for a 440(.055 over) build and a 400(.035 over) build. These are brand new never installed. No damage.
Icon Piston IC-828.These pistons are a 4.375" bore Flat Top piston which will work in either a 440 block with 4.25" stroke and 7.100" rod "512CI" stroker combination, or in a 400 block with 3.915" stroke and 6.535" rod "470CI" stroker combination. The compression ratios and distance below deck will change slightly depending on which stroker combination you are using these pistons with. All pistons use 1/16, 1/16, 3/16 ring pack for less frictional loss, and weight saving, full floating .990 pin size.
This is the piston information www.uempistons.com/index.php?main_page=product_piston_info&cPath=8_9_13&products_id=233&zenid=a8bd6679679aa4f2f15f4666ab155056
Total Seal CR9190 130 Piston Rings, Moly File Fit Bore:4.375" (440 Engine .055" Over OR 400 Engine .035" Over) Ring Width: 1/16, 1/16, 3/16 Tension
Ttt
