I thought I had the squeal in my fan motor fixed but testing it today showed that not to be the case so it will need to come apart. My squirrel cage is stuck on good and tight. I wetted it with 50/50 acetone/ATF mix, shimmed under the cage to pull the shaft up in the motor and give me something solid when I rapped on the end of the shaft with a brass punch and small hammer. Nothing yet gives so I decided to let it sit and soak overnight. Yes, the set screw is removed.
Holding the shaft with pair of clamping pliers and trying to rotate the fan on the shaft hasn’t worked yet.
Any other ideas would be appreciated.
