Thanks 1 Wild R/T.
We have been listening to everybody posts and checking their recommendations against what we have now. The concern is, in the current configuration turning the steering wheel 90 degrees to level it puts the gearbox shaft off its center. I've checked gear box master spline. It is at 12 o'clock with the coupler at 12 o'clock. The master spline for the steering wheel hub is 90 degrees to the left. In this configuration, the steering center gear slop mentioned is there. I also have 1 3/4 turns of the steering wheel both to left and to right from this center position. Car drives and tracks fine.
Contacted Norms Speed Shop in NC who refurbishes these shafts and he states the master spline in the coupler and the end of the steering shaft for the steering wheel hub are aligned to each other. The fact that I have a 90 degree offset is pointing to maybe an earlier years steering shaft where the coupler position, which is dictated by the hole in the shaft might not have had a master spline on the steering gear or in the earlier coupler.
I plan to pull the steering column in the next week or so to see what's in there.
We'll let you know what we find!!!
