My ‘68 Coronet is factory ac with the classic air refresh under the hood. I wired the throttle stop right off the 12v compressor feed at the compressor side. The wire is already 6 inches from the needed location. Once the ac switch is turned on there is constant 12v on that wire.
There are two things that I didn’t do on my first car, ‘67 Mustang, that I said I would always do on every future build. An ac throttle stop was one and a 100% viable emergency brake. The mustangs had drum brakes and a hand lever. No matter how hard a pulled that thing it would always creep if downhill backwards. The Dr diff rear disc with internal drum ebrake fixed this car. Lessons learned, I started with the disc kit that uses the ebrake to a caliper lever. Those should be banned and the vendors selling them water boarded. There is such a fine line on adjustment that you either have a creeping ebrake or groaning car brakes.
