Voss
Lately my Charger has developed an issue when sitting at idle with engine fully warmed. The problem first appeared at a cruise night a few weeks back. The car started to bog out at idle, and eventually stalled. No issues what so ever to start again. It did this 10 times or so in 5 hours so needless to say I got to locate the issue and fix it.
Car is a 68 Charger with a 440, a Carter AVS 4429S carb, and a stock style points distributor. I also have the vapor separator and hard lines to the carb. Tank vent is fine and not clogged. After doing some more investigation I found that when the car starts to act up, I can always save it if I give a little gas. No bogs or issues what so ever when driving, it runs super strong. The issue I have is only at idle. It is especially sensitive if I go from Neutral to Drive and sits at low idle with the foot on the brakes. But it has happened that it acts up even when sitting in neutral. But it is ONLY when the car is fully warmed up (about 190F). Never when cold.
Yesterday I checked the timing, replaced the coil and ballast resistor (since I had these parts on the shelf), but still the same issue. One interesting thing is that I couldn't reproduce the issue when sitting at idle with the hood open. I had the car idling for about one hour (while doing some cleaning of my garage), and it never stalled. But when I closed the hood the issue appeared like after 2 minutes. So SOMEHTING is affected by the heat which builds up in the engine compartment.
I hooked up my dwell meter and it reads stable 31 degrees. It charges good at about 14-13.5V at idle.
I do feel this is ignition related so my next step is to replace the condenser, rotor and cap. They are all fairly new however (2 years). I have more or less ruled out a vapor lock since the car fires right up after it stalls. I am thinking I might have a weak spark, maybe due to a failing condenser, or a crack in the rotor.
Next thing to think about is of course carb and fuel issues, but since it runs super-strong I started in the ignition end. The carb is professionally rebuilt a few years back and has worked perfect. The thing I did replace last season was the distributor, bought a A1 Cardone unit. I have heard both good and bad things about them. But the dwell is stable and it has worked well up until now. Maybe I should mention the ignition is set at about 7.5 deg, and I run ported vacuum to the distributor.
I have to solve this, so the rotor, cap, condenser and points is next in line to replace. If that does not help I am starting to run out of ideas. Or at least I have to start thinking about carb issues.
Any thoughts from someone who has experienced something similar?
