pearljam724
There are vinyls that use a special membrane on the back for these type of installations. These membranes allow air to easily escape when installing. Resulting in bubble free or warp free installation. Your picture proves the point I’m making. If the vinyl has this membrane on the back. ( It looks like a woven spiderweb. ) It will look fantastic and painted on when applied. In fact, it’s hard to screw up and that’s the point of the membrane. Looks like a poor choice of vinyl was used to make this decal.
Regardless, of what yours is made of. If you rest the gauge by a good heat source. Like a wood burner or vent for a furnace. The air will completely work itself out on its own. Sometimes it takes up to a week. But, they are guaranteed to completely disappear. If you’re patient enough. A hair dryer isn’t a good choice. Because the trapped air needs more, subtle consistent time. You need to use a consistent heat source over a longer period of time. A wood burner stove is perfect. Consistent heat, over a long period. Put it on a chair up against the wood burner. Or hang the gauge 3 to 4 feet above it.
