yup, that's the ballast resistor! Most of the 2 prong ballast resistors like that are around 1 ohm so I bet it should be fine. Others here can comment for sure.
You guys have been very helpful. I keep running into perceived roadblocks.
I found here that the resistor I have is probably a 1.25 ohm for part number 254186 that I have:
https://www.forabodiesonly.com/mopar/threads/new-mopar-ecu-harness-and-ballast-resistor.296537/
According to the instructions on the MSD High Vibration Blaster coil instructions, it calls for the .8 ohm resistor MSD part number 8214 so I figured I should buy that since it has a different resistance value from the resistor I currently have. When looking to buy that resistore, the question and answer area on this resistor on the Summit site states the MSD coils will not work well with the orange ECU box I have. Is anyone running this High Vibration MSD coil with the orange ECU box I have without issue?
Link:
https://www.summitracing.com/parts/msd-8214/questionsanswers/
The site states:
Q:
I used this resistor with a Blaster2 coil and the orange mopar performance ECU - a few minutes after starting, the resistor was extremely hot and demaged - engine stops. I put a new one in - same result ???
Asked by ARMIN on April 30, 2017
A:
Can you get a pic of how you wired it. Label what the wires are, B+, ground, signal etc.
TERRY from IN answered on May 06, 2017
0 of
0 found this answer helpful.
Was this answer helpful? Yes | No
report abuse
A:
Apparently the MSD Coils which are designed to be used with the MSD capacitive discharge performance type ignitions will eventually do bad things to the Mopar ECU's. Unless your running the full MSD ignition (MSD distributor/6AL box/Blaster Coil) it will likely happen again. Try another ECU if you have a spare one or try replacing the ECU and use your old stock coil...bet it works.
GREG from PA answered on May 05, 2017
forbbodiesonly members, any advice?
