Good luck Mr. beanhead, I'm rooting for you!
I hope not! I recently replaced it, using the sturdy stuff..is the pcv hose collapsing?
Just that is a sign, the crankcase isn't getting vented...or not enough.dipstick was pushed up out of the tube an inch or two.
That's good news, I was just wondering about the increase with the oil squirt...I think this engine's gotten in my head!Geez, your within 3% on all cylinders. I’d say that’s pretty damn good. Also number seems alright given the compression ratio.
Thanks for replying. The engine is not stock, and I use a windage tray. The builder did explain the exact number he bored to, to get all the cylinders round and straight. It had previously been poorly machined..For now I'm driving it and not slamming my foot to the floor (that's the only time it's passed oil). I'm giving it a couple hundred miles, and if it doesn't clear up after that I'll address it further..Mr. Beanhead is your 440 all stock? I have had engines where the crankcase pressure was not what was shoving the dipstick out. It was more due to oil windage from the crankshaft stirring the oil enough to were it would hydraulicly shove the dipstick out. On BB mopar it seems like we ran into it with a stock oil pan and no windage tray. There is usually some crankcase pressure on all engines. But too much oil in your engine, bearing clearances, shallow stock oil pans, HV oil pumps, the dipstick itself, and engine rpms can all cause the engine oil to actually push a dipstick out..
The engines I have been around that were so wore out that they could blow a dipstick out didn't have the cylinder pressure your running. But, anything is possible, but my guess is rings are already broke in or if it is causing all this they never will brake in. I have seen more slow brake in problems from machine shops not using honing plates and out of round cylinder bores then ring problems. If it's out of round it may take a long, long time to wear everything in.
Your valve cover gaskets may not have been pushed out, but were not sealing up and slipped out...a BB mopar valve cover can be challenging to get sealed up unless you have a nice set of Aluminum ones.
You're correct about no smoke or loss of oil...and yeah I run a milodon stock type pan. After high rpm, just oil on top and back of the engine. Enough for a small puddle after it sits a bit. Fine any other time..What oil pan are you running? I have had the dipstick pop up with and w/o a windage tray and it always happened after high rpms with a shallow oil pan just like you are describing. I have never had any trouble when running a deeper oil pan. Blowby and noticing blue smoke or oil consumption would usually come along with rings failing. It doesn't sound like you have any of those symptoms....unless I missed something. Lol
Is the valve cover with the pcv able to use another breather instead?
What type of breather in currently being used?
I’ve seen it numerous times where the breather itself gets saturated with out, then when you go sail on the motor a bit, there’s a little mess under the hood.
Clean out the breather, problem goes away....... until the breather is saturated again.
I usually see this on motors where the baffle in the valve cover isn’t doing a good enough job of keeping the oil mist out of the breather.
No new developments on the oil issue...I've been putting miles on but no hard full-throttle blasts(so no oil leakage). Been concentrating more on getting things working with the timing it seems to want, and fiddling with ported vacuum advance. At the moment it's got good response off-idle with the distributor curved for 31 initial, 37 total, and about 10" vacuum. The engine cruises between 15"-20" of vacuum depending on speed so the full amount of advance is never realized as the can adds timing over about a 10" vacuum range. Any throttle drops it to under 10", which is good for no pings under any acceleration. Vacuum advance is adjusted to start pulling in at about 13", makes the total advance at cruise around 48-50 degrees. It might like a little more in which case I'll turn the allen screw on the can in another 1/2 or full turn. I just don't want it starting too early and causing any pinging when I give it more throttle. (All this is verified with a vacuum tester, and gauge connected while driving.)Any changes worth speaking of Mr. beanhead?
