Joel Talka
Happy New Year All;
I have another question on my '66 Coronet. The car has a worked 408 small block in it and produces a relatively low vacuum, 10-11". I have a vacuum can in there to generate enough from the carb base to supply the power brake booster. I mention this but I am not sure if this figures into this issue.
The issue is that I can't seem to get the idle to stay put. I'll warm the car up and set the idle to roughly 1000 RPM. I'll take it for a short ride and as I am driving, the idle will not return to that setting but rather adjust up a couple hundred RPM to like 12-1300. I've checked the distributor advance which does not begin to kick in until around 2K. I don't see any cable binding either. I'm wondering if this could be related to the vacuum can......
As always, I appreciate any thoughts or suggestions..
Joel
Joel
